1010 hydraulic or gear lube leaking
gasmith
09-07-2005 06:40:27
I have a 1963 1010 gas. I've noticed twice while running the tractor that I have either hydraulic fluid or transmission/rear end gear lube leaking in three locations. First, it seeps out what looks to me like a hydrualic line connection under the operator's seat and runs down on the LH brake housing and onto the LH foot pad. Secondly, it seeps out of the access hole for the clutch throwout bearing adjustment. Thirdly it sprays out somewhere near the joint between the rear of the engine and the front of the transmission. It is not engine oil.
I changed the gear lube in the transmission and rear end this spring and added more than what the spec called for. I kept adding lube until it came up to the inspection holes (rear end) and up to level in the fill port for the transmission. I probably in total added 1 - 1.5 gallons more than what the capacity called for in the book. Is it possible that it is overfilled and that is why it is leaking in the spots I mention? It does not do it all of the time. Why does it leak where I mentioned? It might be possible that leak under seat is separate issue with hydrualic system.
