JD 300 backhoe Water pump
GH in OH
09-07-2005 06:01:21
I have a JD 300 Backhoe and the water pump went bad. I am having a hard time finding one. I was wondering if anybody knows where to find a used one (or another website to ask this question). I am told the 300 is the same as a 1020. If this the case, can i just order a new pump for a 1020 and put it on the 300? Thanks in advanced for you help.
Roy Suomi
09-07-2005 20:57:35
 Re: JD 300 backhoe Water pump in reply to GH in OH, 09-07-2005 06:01:21
Where in Ohio ?? I'm in NE Ohio . 30 mi. east of Cleveland. It takes me about 20 minutes to rebuild a pump.If close by, drop it off.R.S.
GH in OH
09-07-2005 09:03:33
Thanks for the information. I thought about a rebuild, but have never done one before. I will give it a try. In addition, to answer a few questions i should have had in my first post..... It is a diesel and i am not sure on the serial number. Thanks for the feedback. I really appreciate it.
Mike M
09-07-2005 09:37:52
 Re: JD 300 backhoe Water pump in reply to GH in OH, 09-07-2005 09:03:33
Most JD dealers shop will do the rebuilding for you if you take it off and bring it in if you don't have a press at home.
Bob
09-07-2005 07:42:39
A quick search of JDPARTS shows a number of complete new waterpumps, depending upon serail number, and gas or diesel, at least several of which are still available, but $$$$.
Had you posted the serial #, and whether it was gas or diesel, I could give you a more accurate answer.
A bearing and a seal kit will only set you back about $30.00, and they're readily available.
Is your's too far gone to rebuild, or did you not realize that it is more common to rebuild waterpumps on Deere equipment than to replace them?
donmyeil
09-07-2005 07:39:58
Why not rebuild it ? It would be a lot cheaper, and not hard to do. Instructions come with the kit.
