JD 60 Power steering hose conversion
Fred from MO
09-07-2005 02:35:33
I have had the pressure side steel hose snap off at the fitting on the power steering pump due to age, rust and vibration. I am going to try to save the unique ends of the original line and weld them to a more modern 1/2" hydraulic swivel connection, and then run a regular hydrualic line. Has anyone ever tried this, or would you have a better idea.
Mike M
09-07-2005 05:25:52
 Re: JD 60 Power steering hose conversion in reply to Fred from MO, 09-07-2005 02:35:33
The pressure side at the pump should allready have a hose ? The suction side is a metal pipe.I would guess you could fashion some kinda hose on there ?
Fred from MO
09-07-2005 09:40:39
 Re: JD 60 Power steering hose conversion in reply to Mike M, 09-07-2005 05:25:52
Ok My mistake. I thought the top of the pump was the pressure side.
Mike M
09-07-2005 09:48:51
 Re: JD 60 Power steering hose conversion in reply to Fred from MO, 09-07-2005 09:40:39
They both go out the top of the pump,unless you have some kinda aftermarket unit which is possible.They can be set up many ways.
