JD 50... installing a Power Block- a good idea?
jd50_tye
09-06-2005 20:09:33
I am tossing around the idea of putting a power block into my 50 when I do a mechanical restoration. I understand that a power block will jump up the power about 6 horsepower. This will make the 50 capable of pulling a 3 bottom plow and a 10 foot disk. I kind of like the idea of having the extra horses. Has anyone done this to their tractor? Does anyone have any pros and cons to the idea? Thank you for any input. --Tye
jason r
09-07-2005 18:17:55
 Re: JD 50... installing a Power Block- a good idea in reply to jd50_tye, 09-06-2005 20:09:33
no there is not.... buy a 60
Mike M
09-07-2005 09:44:07
If you have a power block laying around go ahead and use it.They were used for years out in the fields with good results.You may however get a good gain in power just from a fresh overhaul done right with normal parts. Or if you have a power block laying around sell it and sell your 50 and you should be close money wise to pick up a 520 or 620.
Mike Aylward
09-07-2005 08:00:43
JD50, I'll put in my two cents worth here. A Power Block will gain you power. No argument there. However, they are hard to find and expensive when you do. They are harder to assemble as the rods and pistons go in from the BACK rather than the front. The block, pistons and rods will have to be installed as a unit. Overbore pistons can be had for these blocks but cost more, too. If you are looking to add more power to your 50 it can be reasonably done with additional length aluminum pistons. They will get you up around 40 h.p. and will be reliable day in and day out. A ten foot disk is pretty optimistic for a 50 even if it doesn't cut very deep. An eight foot would be more to it's liking in most soils. We used to have a '51 B that was "enhanced" and it would pull 3-14's in gumbo in third gear all day. It dyno'ed 40 h.p. and ran for years that way. But we took care of it and didn't "ram" it. A 50 should get just a tad more. You will not tear up a 50 with either of these setups. But conventional pistons with your block will be easier and probably cheaper to find. Mike
power block
09-07-2005 11:18:17
 Re: JD 50... installing a Power Block- a good idea in reply to Mike Aylward, 09-07-2005 08:00:43
Mike, what are those PB's going for now? And for the 50, which one is that?
Mike Aylward
09-07-2005 12:47:07
 Re: JD 50... installing a Power Block- a good idea in reply to power block, 09-07-2005 11:18:17
The PB for the 50 is unique for a 50. I believe it is a "5-3". I'm not sure of the price, but tractor pullers will hock next weeks lunch for one. Mike
phil2
09-07-2005 07:41:58
The extra power doesn't really give you the capability of pulling bigger implements, that requires a heavier tractor. It gives you the capability to pull your smaller implements at a higher speed. One downside is that you will damage implements as you hit rocks, etc, at the faster speeds. Another downside is that your higher gears will wear faster, you'll be using 5th for tillage.
55 50
09-07-2005 07:15:12
A 50 should pull a 10 ft disc without any HP increase. Maybe it would have trouble on hilly ground. I pull a 10 ft disc on fairly level land and have no problem.
buickanddeere
09-06-2005 22:59:11
You can gain as much or more reliable power by purchasing a 520 or 530 as a minimum. Better yet a60,70,620,630,720 or 730. The 20 and 30 series have a real three point hitch too. As for taking a 49+ year old peice of high hour equipment and working it steady at 20% over the factory max rated power? While the factory recomends running the tractor at 80% with a 20% reserve for tough spots? It's your pocket book.
