How much is a JD 720 L.P. worth?
JD runner
09-06-2005 17:54:10
I'm thinking of purchasing a 1957 John Deere 720 L.P. with what looks to be a factory wide front. However the tractor's is sad shape. It has no good rubber, rims are about shot(one already is), the sheet metal is in very poor condition, and the engine is stuck tight. However the tranny seems like it might be ok. So how much is this tractor worth? All opinions are much appreciated.
buickanddeere
09-07-2005 08:57:05
 Re: How much is a JD 720 L.P. worth? in reply to JD runner, 09-06-2005 17:54:10
Search the serial number to make certain it doesn't have some exotic history.
1111111
09-07-2005 08:47:44
gallon of gas 3.39
book of matches .49
big A$$ fire ... priceless so i would guess about 3.88 give or take
55 50
09-07-2005 07:23:35
From the previous comments, I would gather that LPs aren't worth nearly as much as non-LPs. Here I thought just the opposite was true! What gives!
Ben.So.Tex
09-07-2005 04:18:14
730lp not running engine free 350.00 under a shed
720lp bad tran engine free wide front outside 300.00
720lp stuck outside GOOD ruber and metal 600.00 All these tractors are working great now and have been almost trouble free ( gasket leaks power steering leaks seal that had dryed out most repaired now) all had good to fair rubber and the metal was good. I really enjoy them. I would not give more than scrap iorn weight for the one you looking at. You will spend alot of $$ to repair it. There are plenty of them still out there, you just have to do some tractor hunting.. My two pennies Good Luck BEN
Merf
09-06-2005 19:35:08
I have a 620LP, paid $750.00 for it last year. It has a nice square front end, good sheet metal and it does turn over but have not tried to start. I had some spare wheels, 3 point etc so thought it was worth the price.
woodbutcher
09-06-2005 18:57:04
JD,
I don't have any current info. for you, but I bought one that was in fair shape twenty years ago and sold it after working it pretty hard for 5 years. I gave $2,500. for it and sold it for the same amount. Mine had an aftermarket wide front end. I later bought a 3010 LP with hydraulics that didn't work. I used it that way for several years and made $500. when I sold it. I now have another 3010 LP with working hydraulics. I gave $4,000 for this one, and I've had it 10 years. I think it's worth $4,500. now.
People around here say that when you buy an LP tractor, your married to it. I haven't found it hard to sell the ones I've owned.
Butch
