1939 B block
Mike n Mo
09-06-2005 16:16:49
I'm trying to answer a question for a friend. What year engine blocks will interchange with a 1939 B? Also, does anyone have a source for replacement 4.5" pistons (oversize). Thanks, Mike
SWI Don
09-07-2005 19:13:36
 Re: 1939 B block in reply to Mike n Mo, 09-06-2005 16:16:49
As said only 1939-1940 block will work. The oiling system for the tappets is different. The later blocks 41-47 have the oiling system going through the bottom of the block (pain in the rear to hook up).
They also used this engine on the BR / BO's up to the end 1947. They never later engine.
Don
jd b puller
09-07-2005 20:31:37
 Re: 1939 B block in reply to SWI Don, 09-07-2005 19:13:36
SWI, you wanna see a pain in the rear end to hook up? I just put a 5-2 PowerBlock in a 44 B. Had to tap the block at the back to put a fitting in there for the oil line. Had to make up a special oil line to go from the pump to the block. But the catch is you can"t hook it up until the crank, pistons, rods and everything is in place. I think I spent 30 minutes or more just fumbling with the pipe that you can"t see and almost can"t reach before getting lucky and getting the nut to start. Would have been a lot easier if the line I had was copper, but all I had was a piece of steel line.
Earl-IL
09-06-2005 21:24:36
I think Hinrich's has some pistons.815-778-1900. Earl
430WLPG
09-06-2005 18:14:22
They are a odd duck and ONLY 39-40 WILL WORK and be correct!!!!!.The later might bolt in but the upper water pipe is different, I guess you could swap the water pipe also
Green B
09-06-2005 17:18:53
Link
Mixman
09-06-2005 17:17:15
39 to 47 Be sure to check casting#
Mike n Mo
09-07-2005 06:53:29
 Re: 1939 B block in reply to Mixman, 09-06-2005 17:17:15
Thanks for all the responses. I'll pass the info along. Mike
