2010 diesel dies
bow7n
09-06-2005 16:08:20
Hi, I have a problem with my 2010 diesel tractor.It will run fine for an hour or two then it starts surging like it is starving for fuel then dies.Then it is hard to start.I dont know if its trash in the tank or lines,air leak,injection pump problem or what?Any help would be great.
Jed S
09-06-2005 20:35:30
 Re: 2010 diesel dies in reply to bow7n, 09-06-2005 16:08:20
Make for sure the fuel return to the tank is clear. Check the filters. Check the supply from the tank. If all check out the the governor ring in the pump could be going bad. If the ring is going bad sometimes if you open the timing window on the pump you will see debris,or when you check the fuel return to the tank if it is plugged it probably is the governor ring. If you pull the pump it has to be timed first. If you are not sure let someone who knows what they are doing pull it.
WV2cyl
09-06-2005 17:24:02
I had the same problem with a newer 5400 with 200 hrs and we about lost our minds finding that mud dobbers had built a cell in the vent hose of the tank.
