Dual Wheels
Big 3010
09-06-2005 10:15:02
How many of you have or have seen 3010"s and 3020"s running dual rear wheels? I would like to run dual 13.6-38"s on my row-crop 3010 and am looking forward to seeing how it pulls them. John Deere still offers dual wheel hubs and rims to fit the 3 1/8""axles on the 3010. Any thoughts?
buickanddeere
09-07-2005 09:10:45
 Re: Dual Wheels in reply to Big 3010, 09-06-2005 10:15:02
As previously stated, soft soil with high rolling friction? Or hard soil? Finding a properly sized set of radials will allow running them at 6 psi to reduce soil compaction. Won't cost you anymore than a 2nd pair of tires, rims, hubs etc. You won't have to be puling duals on and off all the time. Or worrying about width on the road or getting into a shed.
onefarmer
09-06-2005 13:56:18
I have a 3020 with 16.9x34 snap on duals and it makes a big differance. Pulls the implements much easier in the same gear as with singles. I atribute it to not having to climb on top of the dirt in loose soil. Floats better
Able
09-06-2005 10:44:07
It depends if you really need them or not. It's not going to give you any more power,only better traction . It will also add more stress to your drive train. If your only putting them on there to make the tractor look bad, then you are wasteing your money. Usually adding weight to tractors under 80 hp will solve any traction problems.
