B rear axel seals
Pete/ME
09-06-2005 04:35:21
I tried the archives, but couldn't find how to replace the outer grease seals (felt?) on a 215xxx B. The S.M. is pretty vague, with different styles for earlier machines. Don't want to pull the axel if I don't have to.
Mike M
09-06-2005 05:00:03
 Re: B rear axel seals in reply to Pete/ME, 09-06-2005 04:35:21
If you are leaking out oil your going to have to pull the axles as the oil seal is at the inner end of the axle next to the bull gear.Just pull the axles by loosening the nuts and putting a wedge between them forcing them out and the outer felt & retainers will pop out so they can be reused with new felts.
RalphinWI
09-06-2005 09:16:53
 Re: B rear axel seals in reply to Mike M, 09-06-2005 05:00:03
Also need to remove the pool of oil in the lower part of the housing between the oil seal and the felt dust seal.
