830 bleeding fuel system
Leroy Falk
09-05-2005 17:29:09
I cant seem to get the fuel to bleed from either of the filters bleed screws.This tractor has been sitting for a long time and i can't get it started
Gerry_Luzerne_MI
09-06-2005 10:04:13
 Re: 830 bleeding fuel system in reply to Leroy Falk, 09-05-2005 17:29:09
Leroy: With the fuel system all together, remove the 2 bleed screws from the first two main filters. Take the fuel filler cap off. Put a clean rag over the tank opening and take a deep breath and blow into the tank. You may have to do this a couple of times depending on how much fuel you have in the tank. What you have is a air lock on the primary pump and this will start the fuel flow. I have done this with my 720D a couple of times when I have run it out of fuel. Good luck... Gerry
lonzo
09-05-2005 18:34:04
remove sediment bowl under fuel tank and open valve, nothing happens then unscrew the bowl body and clean there, if nothing is wrong then remove fuel line on fuel pump fuel runs fine then remove the other fuel line and crank engin and see if pump is working and keep checking the fuel lines untill you find the trouble. the last 730 in the shop i installed spinn on filters and bracket off of a 3020 worked good
