Bad news: broken block
in-too-deep
09-05-2005 13:54:16
Just discovered why my '49 B was parked. The inside cylinder wall on the no. 1 cylinder collapsed. A 2" by 4" piece of the cylinder wall is broken out into the water jacket. Don't understand how this happened, but I know it made a bad day for this guy. Has anyone ever seen this before? I doubt it can be fixed, and if it could, it would cost more than finding a block to buy, and would never be the same. I'll work on getting the cylinders out while I wait for some sympathy from fellow JD folks. Thanks.
Chris
john tabor
09-05-2005 17:44:11
 Re: Bad news: broken block in reply to in-too-deep, 09-05-2005 13:54:16
hi. try marlin smith in iowa for all kinds of parts jd. he knows his stuff and is a great guy to deal with. call him at 1-712-489-2570
Mike M
09-05-2005 15:53:59
A good machine shop should be able to sleeve it for you.
F-I-T
09-05-2005 16:50:04
 Re: Bad news: broken block in reply to Mike M, 09-05-2005 15:53:59
I'd guess that from the sleeving costs the guys have been reporting that it would probably be less expensive to find a servicable "B" block. They made so many of those I'd bet you can find a decent one and have less money in it overall thant you will sleeving your old one. I could be wrong, as I often have been, but I'd look for a different block. Also, sleeving a JD two cylinder is typically done as a dry sleeve, and in this case with a chunk missing, you would have to seal the water out via the sleeve. It's another place for problems to recur.
Frank
