Head Temperatures...Too High?
Gary U in CA
09-05-2005 10:13:27
Curious,
With the convenience of digital temp gauges does anyone have some reference of static head /exhaust temperatures?
The reason I�m asking � I�m working with my first gas 2 cylinder (720) and it seems like quite a bit of heat being generated. One fear is that the cooling system may not be functioning properly. Prior to opening up the tractor I figured I�d get everyone�s thought on troubleshooting.
What�s normal��bad thermostat��.blockage��
Anxious to hear your thoughts!
Gary
buickanddeere
09-05-2005 17:38:04
 Re: Head Temperatures...Too High? in reply to Gary U in CA, 09-05-2005 10:13:27
There is probably nothing wrong with it. A gasser when just putting around, has hotter exhaust than a lightly loaded diesel. Engine coolant should be no less than 180F and 195F is better.
twopop
09-05-2005 11:38:49
for gasoline,the exhaust manifold temp should be right around 500 degrees
twopop
09-05-2005 11:38:37
