CYCLONE JD A????
oldironfan
09-04-2005 23:23:40
In a past discussion with a old friend, I heard mention of an experimental JD A called a CYCLONE A,in which JD tried to get more power from a JD A by placing a larger flywheel on the tractor. This was suppossedly done in what was called "THE BUTCHERBLOCK TESTS" that were secret tests done in the early 50s.
Does anyone have any idea? If so,are any of the tractors left?
jas
09-06-2005 15:20:42
 Re: CYCLONE JD A???? in reply to oldironfan, 09-04-2005 23:23:40
Not every Styled A used a cyclone head. There are us that have 39's and they were unstyled tractors with styled clothing.
steveatexas
09-05-2005 18:56:36
the truth of the matter is that cyclones also had other improvements such as drive discs , clutch, crankshaft , and the eyebrow in the head all comming together to produce about 4 more horsepower ,in 1950 mid year these changes were made,these new tractors were the cyclones not all tractors from 47-52 if i am wrong correct me as i hate to spread hear say, god love yall ,STEVE
buickanddeere
09-05-2005 08:09:27
Yes they are rare. JD only made 117,965 Cyclone model A's from 1947 to May 12th 1952. Serial numbers 584000 to 703384. The Cyclone head was before it's time. It's what General Motors started with the Vortec engines, LT1/LT4 and now with the LS1,LS2,LS6 plus the plain boring pickup truck engines.
Tx Jim
09-06-2005 04:54:46
 calculators????? in reply to buickanddeere, 09-05-2005 08:09:27
buickanddeere,do canadian's calculators work different up in snow land? Down here in Texas if you put 703384-584000 in calculator the answer is 119,384. Just curious, Tx Jim
buickanddeere
09-06-2005 07:15:48
 Re: calculators????? in reply to Tx Jim, 09-06-2005 04:54:46
Everything is bigger in Texas so that may explain yours and my numbers. Some serial numbers were scrapped by Mother Deere.
Drew
09-05-2005 12:55:19
 Re: CYCLONE JD A???? in reply to buickanddeere, 09-05-2005 08:09:27
What I don't get is that people think the late A with the cyclone head is so special, but the early styled tractor's cylinder head (A2325R) has the same d@mn combustion chamber design (but deeper in the head for the reduced compression), and no one ever calls them a cyclone tractor. Every styled A had a "cyclone" head on it...nothin' special.
buickanddeere
09-05-2005 17:52:00
 Re: CYCLONE JD A???? in reply to Drew, 09-05-2005 12:55:19
Drew, I was pulling then guys leg when saying nearly 118,000 tractors are rare. I didn't intended to say a 47 to 52 cyclone is super special when during the 1st re-design in the late 30's/early 40's, can't remember. The heads did get the ramp and swirl intake. What I ment was the Cyclone/swirl design it's self, not the 47-52 tractor is the smart engineering or collectable.
Drew
09-05-2005 19:23:42
 Re: CYCLONE JD A???? in reply to buickanddeere, 09-05-2005 17:52:00
I knew you were being sarcastic, I even found it pretty funny. What I was wanting to know, and this is a question for anyone, is why people advertise them on Ebay or in other places and act like they are special. Because like you say, they made 118,000 late A's and even the A's before then had the "cyclone" style head on them.
And B&D, your sarcastic responses have made my day just a little better on several occasions. Its like Mr. Thinker, but without having to wait for the magazine to show up :)
buickanddeere
09-05-2005 21:07:17
 Re: CYCLONE JD A???? in reply to Drew, 09-05-2005 19:23:42
Thankyou Drew
As F.I.T has posted something to the effect of. "Some people are a good example and other people's lives are a warning". Somebody has to make "Mr. Thinker" seem like a decent fellow by comparison. Now to think up a witty reply to Frank's plough, plow,cow & cough remark. Gonna have ta sleep on that one.
