Hydraulics for a JD loader
fatbob50
09-04-2005 22:11:02
I have a John Deere 2440 (1977). I would appreciate some advice on the best way to hook up the hydraulics. It has one set of remote hydraulics. I would appreciate any information you could share on the best way to hook it up. Thanks, Bob
cannonball
09-05-2005 10:04:19
 Re: Hydraulics for a JD loader in reply to fatbob50, 09-04-2005 22:11:02
get a seperate set of valves for loader, come off the high pressure when the remotes get pressure, usually change fitting to a tee...get a new filter cover that has a tapped port...put your return back in there..the valves for loader must be closed center valves.. this is probably cheaper in the long run rather than add another set of remotes, plus you have to unhook loader lines to used remotes...have nice day may god bless
