rebuild B carb.
scott ind.
09-04-2005 19:06:44
I got 1950 B that will start up with choke closed
and not much throttle. if you give it gas or open
the choke it dies. this b has been sitting a year or two . So I would like to get the carb. rebuilt. Is there a kit with good illustrations or i'm i better off shipping it somewhere?
P Browning
09-05-2005 09:12:29
 Re: rebuild B carb. in reply to scott ind., 09-04-2005 19:06:44
Scott -- It appears you have some blockage in the IDLE path of your carb. And it does appear that you have very limited association with carburetors for JD two-cylinder tractors. Thus I would like to send you a draft copy of the carburetor chapter for a book I am re-writing (2nd Edition). Send me an email for that.
In the meantime, there is a test you can run to determine which part of the carb is messed up. Its clled the LOAD & IDLE test. Post back with the results. (PatB)
Testing -- LOAD & IDLE Pathways -- A test is conducted to double-check your carburetor's IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: (1) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. Oh -- and take those needles down to their limit nice & easy! (2) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below.
(3) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked. ++++
Walt in Jaxn Tn.
09-04-2005 20:54:47
I assume you have little or no experience rebuilding the DLTX, so first, I'd get a small tank like a lawn mower fuel tank and fix it so that it stays above and to the side of the carb (I hang mine over the hood with a wire)Remove the tractor fuel line including the brass fitting (take good care of that fitting, they are hard to come by)that goes into the castiron bowl where the fuel line goes in. Go to the hardware store and find a fitting that will replace that brass fitting but will allow you to push a rubber fuel line on the other end of the fitting. I don't know what the fitting is called and I'd draw you a picture if my scanner worked. Put the other end of the rubber hose on the lawnmower fuel tank and put a pint can of "denatured alcohol" in the lawnmower tank and allow it to fill the fuel bowl (make sure the gas has been drained out of the carb first)with the denatured alcohol. Let the denatured alcohol set for a couple hours or longer, this will disolve the varnish completely out of the carb and can be run in the engine. As far as I know it will not touch rust. Reset the idle and load needles. If this does not help, then I'd remove the carb and send it to a reputable rebuilder and have him repair the carb. --Walt--
john tabor
09-05-2005 17:52:19
 Re: rebuild B carb. in reply to Walt in Jaxn Tn., 09-04-2005 20:54:47
see other post on carbs!! i did sand blast mine to get the rust out five years ago and have had no problem with it. of course you have to clean it good afterwards
P Browning
09-05-2005 17:56:45
 Re: rebuild B carb. in reply to john tabor, 09-05-2005 17:52:19
Sand blast your carb at risk! Just be aware that 50 to 60 years of time have already taken their toll in metal from that carb body. Sand cuts into base metal where glass beads bounce away. The difference is less loss of base metal with glass beads. And if you don't have a glass bead both, take the carb body to your local automotive machinist who, for $5 or $10 will clean your carb casting up for you in no time. (PatB)
scott ind.
09-05-2005 19:16:57
 Re: rebuild B carb. in reply to P Browning, 09-05-2005 17:56:45
pat is there a cold set( with engine not running) for the ideal and load this tractor was not really set It was toyed with when I got it. but I can get it
to run at low speed.thanks for your time
