I'm not sure that it's real easy to make an informed decision without seeing the finish first hand. But, that said, I have polished many, many, cranks and shafts with a good grade of SC belt (Silicon Carbide) so you get a good, tight grained finish. You should realy polish in one direction so as to lay down the polished nubs so they are laid down opposite of the direction of rotation. The tough part is getting someone to turn the flywheel over and over again while you polish. I have even rigged up an overhead support for a belt which was torn to width of the crank journal, and spring loaded it with a screen door spring to keep steady tension on the belt. That way I could enjoy turning the flywheel myself. Remember, when they "TURN" a crank they grind it, and then they polish it, using several grits of SC belt. Go to a crank shop and ask them for an assortment of worn out belts. Their worn out belts will do you fine. Start at a fine grit and see how far you get with that before dropping down to a coarser grit. It's better to spend more time with a fine grit than over work it in the interest of expediency. It should be cloth belt, so you can put a few drops of oil on it to lighten the cut. Lard (or margarine or Crisco in a can) will work fine as well. Mike it at several places with a quality instrument, hopefully one that you have a standard for. What you are aiming for is round and not egg-shapped, which most two-cylinder cranks are by now. If it has babbit bearings, snug them up to the low limit and try it that way, running at slow speed until it has a chance to wring in to the new finish. I know this flies in the face of proper engine building, but you have to remember, these engines turn at most 1400 RPM, so treating them like a 327 is a bit of over kill. Now if it were diesel, that might be a different matter, but I have pollished them as well. Frank
