J D A transmision oil capacity
wilson
09-04-2005 07:48:42
Just put new differential to main housing gasket in 1944 A Now how much oil 80-90 do I need to buy????
john tabor
09-05-2005 17:06:16
 Re: J D A transmision oil capacity in reply to wilson, 09-04-2005 07:48:42
call your local jd dealer. i think its surpose to be 140-150 weight. this weight oil will keep down the noise in these old rear ends. there is a plug on the side that you remove to see when the oil level is right. if you haven't drained the rear end completely i would do it before adding any to it. it'd probably full of water.
Island A
09-04-2005 13:03:58
I agree. Get the manuals.
FYI my 1949 A takes 7 gallons.
Dave
xragman
09-04-2005 10:41:56
wilson
with a 44A youneed a good manual,whitch will ttell how much oil to use. my b hold right at 5 gal.
another wilson
wilson
09-05-2005 08:44:50
 Re: J D A transmision oil capacity in reply to xragman, 09-04-2005 10:41:56
After paying a LOT for jd parts manuel suppleementto putlive hydpump on and supplement for yakama hitch None of this info has capacities like other companys
