Brush hoggin question
Fred from MO
09-03-2005 18:11:55
I have just started to brush hog with my 60. My buddy is telling me I need to run the engine wide open while I brush hog. I thought since I have live power, I would not need to do this. Anyone have an opinion on what gear and RPM works best on hogging down regular weeds in open flat feilds. Hi RPM"s on the 60 rattles my teeth loose.
wolfman
09-04-2005 17:35:50
 Re: Brush hoggin question in reply to Fred from MO, 09-03-2005 18:11:55
Depends a little on what you're cutting & how big the mower. Your buddy is correct-should be at or near 540 PTO rpm. Check your 60's tach, but I think for 540 the tractor is about wide open(which is only 975 rpm). I usually use 3rd gear near wide open on a 6-ft rotary. 1st & 2nd gears are so slow you're not sure you're still moving & tend to want to step off!
wolfman
09-04-2005 17:34:35
CLW
09-03-2005 22:37:17
Fred, if you are new at it, be sure that the tip of the blade in the front cuts about one inch lower than the back. This takes a strain off the tractor. Depending on how heavy the grass is will have a lot to do with what gear. Try first, then second if your grass is very thin. If the load makes the engine load up, drop back a gear.
CLW
Mike M
09-03-2005 19:40:47
That 60 should not rattle your teeth loose !!! Someone has more than likely put the clutch driver or flywheel on wrong and out of balance. Check and adjust your fast idle (wide open)rpms also.
old
09-03-2005 18:42:08
I'd run about 3/4 open and most of the time 1st gear unless its only grass and then hope you don't find any of the rocks that can never be found in Missouri. I never hog in any thing but 1st. And I'm up close to the lake of the ozarks. I prefer to take it slow and keep equipment in one piece.
old
09-03-2005 18:41:44
old
09-03-2005 18:42:02
