JD 2510 Quit on the Job
Dug
09-03-2005 16:20:14
Mowing a pasture with weeds about 5 foot high, lots of pollen and junk flying around, then the JD just quit. Didn't sputter, just shut down. I was watching the temp gauge pretty close as it was running a little on the warm side, not hot but warmer than usual. Too hot to stay out there and stare at it, going back after it cools down a little.
Any guesses? Fuel filter? (The tank was full, just filled it last week.) Checked the anti-freeze before I started, it was full.
Been a long day, fixed the blown head gasket on the Ford this morning, had the F935 running hot, I think it is the thermostat, will fix that on Tuesday. Now the 2510...
Dug
Paul in WI
09-04-2005 19:41:18
 Re: JD 2510 Quit on the Job in reply to Dug, 09-03-2005 16:20:14
Last year my 2510 did the same exact thing when cutting hay. After checking everyting else I finally took the carburator off and cleaned it thoroughly. That solved the problem. I don't know if this is your problem but it sure sounds similiar.
Paul
Handsome jim
09-03-2005 18:00:15
That's what I'd do, let it cool down a couple hours and give it a try. We have a 1020 that does that very same thing and I'm pretty sure the coil is getting weak. After a hour or so she starts right up. Let us know what happens.HJ
Dug
09-03-2005 18:28:47
 Re: JD 2510 Quit on the Job in reply to Handsome jim, 09-03-2005 18:00:15
Went back this evening and it started right up! I mowed for about 50 yards and it died again. Checked the fuel filter and it's not plugged.
Any suggestions?
Dug
BTW, the tire is going flat, just to add insult to injury!!!(At least it is the front and not one of the loaded rear tires: )
j cook (iowa)
09-03-2005 20:13:43
 Re: JD 2510 Quit on the Job in reply to Dug, 09-03-2005 18:28:47
Several years ago brush cautting tall weeds, with a 3020G, under the same conditions, my 3020 just stalled out. It was the AIR CLEANER, (The 3020 had the dry filter) and it was clogged with dust. A new filter quickly solved the problem and the clogged filter, after being cleaned, became the reserve filter. The tractor started right up with a clean filter in place. The little black plastic restriction indicator would have told me that this was the case even faster, except mine was broken, and surprise, a replacement was something like $35.00 for a tiny bit of plastic, so I dispensed with it!
