180 transmission
kohlton777
09-02-2005 21:21:19
I know very little about mechanics.. I have a 180 with a blown transmission. I have found a used one from a 111 model, I have been told by the seller that it would work for my 180. Any advice please.
Joe Padavano
09-04-2005 15:51:03
 Re: 180 transmission in reply to kohlton777, 09-02-2005 21:21:19
The 111 and 180 both use Peerless 800-series transmissions, but the 111 axles are set up for bolt-on wheels while the 180 uses splined axles and the wheels are retaines with snap rings. You can use the 111 trans in the 180, but you'd need to swap the axles from the 180 into the 111 trans. This is easy but requires complete disassembly of the trans to do it.
Note that While it is possible that you've stripped some gears in your trans, the most common failure of the Peerless 800 series trans is the two gear selector teeth. These are leaf spring bars that slide along the trans shaft and engage notches on the inside diameter of each of the gears as you shift. The teeth on the leaf springs wear down, particularly if you don't fully engage the clutch when shifting. Replacements are $11 each from JD (two required) but again, complete disassembly of the trans is required to replace them. Does the trans work in reverse but skip in forward? That's a sign of worn leaf spring selectors. If the trans slips in both forward and reverse gears then there's a bigger problem.
Joe Padavano
Bob
09-03-2005 21:34:26
You should be able to go to JDPARTS, and look up the trannies for the two to see if they are similar.
If you need a tranny for a 180, I am parting one out for an old fellow. The engine put a valve through the piston, and AFAIK, the tranny was working OK when the engine went.
Email me, if interested.
Steve Hilbert
09-03-2005 22:16:10
 Re: 180 transmission in reply to Bob, 09-03-2005 21:34:26
Yes I am very interrested, the person I am buying this from has very little knowledge of the one he is selling. Please email me at [email protected]
Bob
09-03-2005 21:34:19
