Hydraulic hook up for #8 Sickle Mower on '51 JD A
Oliver Colterya
09-02-2005 15:21:17
Atten Klooney or Frank in Tallahasseeeee!!!
I am in the process of trying to get hydraulic lines from the power trol unit to the #8 sickle bar mower. The power trol unit has dummy plugs in it and the mower has quick disconnect fittings on it. Can I tap into the side of the power trol for hydraulic pressure and return by removing the square head pipe plugs and use pipe nipples, elbows and quick disconnect? Hydraulic fittings to replace the dummy plugs don't exist in Southern Cal!!! Thanks for your helpl
Popper Dick
09-03-2005 11:12:46
 Re: Hydraulic hook up for #8 Sickle Mower on '51 J in reply to Oliver Colteryahn, 09-02-2005 15:21:17
Oliver,
I have a 1950 Model B with a number 8 sickle bar mower and use it often. I am having trouble understanding what you mean by dummy plugs. You indicate they have square heads. This implies to me that they are threaded into your powertrol. this is where I have trouble believing this (no insult implied).
My powertrol has push in plugs for my remote hydraulic cylinder. I also have dummy plugs that push in to divert my powertrol hydraulics to the jack shaft for cultivator applications.
Hope you don't go farther than you need to.
Good Luck
Dick
Oliver Colteryahn
09-03-2005 11:49:14
 Re: Hydraulic hook up for #8 Sickle Mower on '51 J in reply to Popper Dick, 09-03-2005 11:12:46
Dick, thanks for your response. Yes, I also have dummy plugs that push into the powertrol unit. There are also 2 square head pipe plugs on the side (right hand). My problem is I cannot locate hydraulic plugs to fit the powertrol unit. Been to the local JD dealer, and several local hydraulic supply companies. Any suggestions?
Jerry (KS)
09-02-2005 17:58:39
If they are the same as an "R" the part number is AF1244R. For a "B" the p/n is A3613R. You could look it up on the John Deere website and see if it looks like what you need.
You REALLY need a parts book so you can tell what power trol you have and what couplings are compatible. Website: Link
Oliver Colteryahn
09-03-2005 12:27:59
 Re: Hydraulic hook up for #8 Sickle Mower on '51 J in reply to Jerry (KS), 09-02-2005 17:58:39
Jerry, thanks again for the tip. I drug out the ol' parts book as you suggested, and found the powertrol plug. It is the same as the b, A3613R, which I ordered from Deere. Thanks a million.
Regards,
Oliver
Fred Jenrette
10-17-2006 20:20:10
 Re: Hydraulic hook up for #8 Sickle Mower on '51 J in reply to Oliver Colteryahn, 09-03-2005 12:27:59
Oliver ! i Was looking on the Web trying to find a way to reach you so im posting here! this is your old freind, Fred here in San Diego please look me up and give me a call !619 840 0079 looking to hearing from you < long time no see, fred
Oliver Colteryahn
09-03-2005 08:03:44
Jerry, thanks for the part numbers. I'll check them out. The local John Deere dealer is really not very helpful with this older stuff. I do have a parts manual for the A, do you have any reccomendation(s) for other manuals? Thanks again.
Oliver
Farmer Jack
09-02-2005 16:56:17
You can do as you say or buy the remote oil lines from a JD dealer, use a 1/2" pipe thread nipple and put a female quick coupler on the back side of the power trol remote oil lines. They are still available from JD and you should get them overnight or in a week depending on the type of order from your dealer.
Oliver Colteryahn
09-02-2005 17:17:39
 Re: Hydraulic hook up for #8 Sickle Mower on '51 J in reply to Farmer Jack, 09-02-2005 16:56:17
I visited my local JD dealer today (prior to my post). Took a dummy plug for show and tell. The guys were baffled..."I've never seen anything like that before"....so, my local JD dealer is related to ***'s on a boar hog...ie, useless!!!
