60 Hydraulic Leak under operator platform
Fred from MO
09-02-2005 11:35:50
I seem to have sprung a leak under my operator platform on my 60. I think the steel hydraulic line had rotted through where they connect under the platform. Anyone know if these are still availible and how much?
Bob seND
09-02-2005 20:08:34
 Re: 60 Hydraulic Leak under operator platform in reply to Fred from MO, 09-02-2005 11:35:50
Might be a good time to Y off it to plumb a loader.
Bob
Heckter
09-02-2005 12:16:31
I just priced one for my 730 and it was $110.00.
You should be able to braze it even if it looks alittle rough, I then sprayed alittle rust converter on it so hopefully that will help. Heckter
mike brown
09-02-2005 13:10:30
 Re: 60 Hydraulic Leak under operator platform in reply to Heckter, 09-02-2005 12:16:31
That is a very common problem. Dirt builds up under the platform and hold moisture against the steel pipes. Mine (730D) were badly pitted in many places. I cut out the middle and fitted a piece of conduit in the gap and brazed the joints and it has worked fine. I think it's time to fix it right though while I can still get the parts,
