3pt bleeds down on 3020.
Bill Tremel
09-02-2005 11:23:05
I have had my 3020D for over a month now, and I LOVE this tractor. I have one concern, or actually, just a question. The 3pt hitch drops to the ground in about a 2 hour period after sitting. Is this normal? My 720 will not drop for days, and it never drops all they way to the ground.
I'm just curious as I'm still learning this tractor.
wolfman
09-04-2005 17:39:48
 Re: 3pt bleeds down on 3020. in reply to Bill Tremel, 09-02-2005 11:23:05
Geese 2 hrs! My 3010 drops in about 2 minutes with engine off.
Mike M
09-03-2005 08:59:03
Our 4020 leaked down pretty fast.I helped it alot by working on the thermal relief valve.
donmyeil
09-02-2005 14:15:42
This is an old problem. First the 3-point is not designed to stay up,in fact if you read the operators manual it tells you to lower the hitch when you shut the tractor off, however it was hard to explane to a farmer why his 4010 would stay up all winter with a plow on and the new 4020 wont stay up. Deere said as long as they worked with the engine running that was abt. all you could do. Now there are some things you can check such as o-rings on the piston, valves for seating and adjustment. The thermo relief valve is a good place to start. Don
Boog
09-02-2005 12:16:18
I have a 3020 gas powershift and my 3pt stays up forever. In fact I discovered that I should keep it down because rain would get in the lower arms and rust them - down, the water drains out.
