70 gas govenor hunting
gordonR
09-02-2005 06:29:59
70 govenor hunting and the carb. has been rebuilt professionaly.It hunts at idle and half throttle, even wide open. any help would be appreciated. Thanks in advance
GordonR
Terry Hahn
09-02-2005 17:37:24
 Re: 70 gas govenor hunting in reply to gordonR, 09-02-2005 06:29:59
I would check the governor weights and shaft. My father had a 70D that the bearing that pushes against the weights was bad causing the governor to not work properly. Hope this helps you out.
8e3k0
09-02-2005 06:41:36
Gordon, I would check the throttle shaft for binding or hang up, plus all the other throttle and governor linkages. If the carb has been recently rebuilt the thottle bushing may be a little tight thus restricting free movement for good throttle response.
Ellis
GordonR
09-02-2005 09:37:21
 Re: 70 gas govenor hunting in reply to 8e3k0, 09-02-2005 06:41:36
the linkage is all free and working properly
8e3k0
09-02-2005 11:33:10
 Re: 70 gas govenor hunting in reply to GordonR, 09-02-2005 09:37:21
Could be possibility of governor weights coming lose and been damaged (had this happen on a 630) governor response becomes lazy.
I would also ensure governor and carb linkage adjustments are set to Deere Technical Manual specifications.
