John Deere Lawn Tractor 180
B Delorme
09-02-2005 05:47:51
Greetings: My lawn tractor (John Deere 180) has decided to do only light work. It start cold, then I am able to light work. If I try to turn on the lawn mower, tow a trailer etc... it babk fires and then stalls. I then have to leave it sit for a few hours before it will start again. The engine turns over fine, it is getting gas. However it doesn't look like it is getting power to the spark plug. I disconnected the plug and tried the ground trick and it doesn't spark
Thank you
Bernie
Bootman
09-02-2005 18:04:17
 Re: John Deere Lawn Tractor 180 in reply to B Delorme, 09-02-2005 05:47:51
Sir, I have a 175 and have had the same problem. On the right side of my engine is a little silver box about the size of a match book or a little smaller. It has electric wires going to it..I believe 3...it is called the igniter. You can buy a universal one at a lawnmower shop that is lower in price than the John Deere dealer but usually the wires have to be modified and they don't last as long. If I remember correctly they are about $50 or less. If you cannot find it I will check my parts book tomorrow in my barn and might find you a part number. Good Luck!
b delorme
09-02-2005 18:57:50
 Re: John Deere Lawn Tractor 180 in reply to Bootman, 09-02-2005 18:04:17
Greetings: Thank you very much for your reply. I called the local John Deere dealer and have ordered one. It is $68.00 canadian which is close to your $50.00 us. Should have it early next week
will let you know.
Thank you again for your help and offer to look up the parts
Bernie
