4020 pto front speed dependant on rear?
Nylon
09-01-2005 20:26:15
CMB left an interesting reply to an earlier post that on his 4010 the front shaft rpm was dependant on what rear pto was installed 540/1000 Is this the case on a 68 4020? Someone else left a post indicating that the front pto on 4020 ran on shorter geared shaft than the rear pto does. I thought that the front pto was driven from the rear pto via long internal shaft? May be that is on the 4010 and not the 4020s. Any clarity here would be appreciated.
Thanks,
John
donmyeil
09-02-2005 14:27:41
 Re: 4020 pto front speed dependant on rear? in reply to Nylon, 09-01-2005 20:26:15
The pto on the front ran the same speed as the rear stub shaft on the 4010. The 4020 ran 1000 on the front always as the speed was changed for the rear only. On the 10 series there was one shaft and you cant make a solid shaft run two different speeds at the same time. Hope this helps.Don
msb
09-01-2005 21:06:27
The front PTO is a [part of the main PTO shaft to the rear of the transmissiom where it is shifted to 540 RPM through a set of reduction gears located in the rear of the transmission housing for the rear PTO only, on the 4020. Both 4010 and 4020 PTOs are driven from the front of the transmnission case through a set of idler gears.On the 4010, the shifting is done at the front of the transmission case via a rod that goes through the center of the shaft.Probably as clear as mud?
Nylon
09-02-2005 10:07:12
 Re: 4020 pto front speed dependant on rear? in reply to msb, 09-01-2005 21:06:27
Thanks MSB.
I can visualize that better.
John
