Gen Lite Wiring Connections with an Alternator
Osage
09-01-2005 15:14:55
When I got my JD1010 the 12v Generator had been replaced with an Alternator because the Voltage Regulator went bad.
The question: Is there any way I can wire the Gen Lite to indicate Alternator status?
Any information would be appreciated,
Osage
John T
09-01-2005 16:18:07
 Re: Gen Lite Wiring Connections with an Alternator in reply to Osage, 09-01-2005 15:14:55
Osage, it depends on what alternator you have and how and if the idiot light is wired!!!!
If it happens to be a GM 10 SI or equivalent and the idiot light were connected to a hot switched (when tractor ON) battery feed on one end, the other end of the idiot light could be used to excite the alternators lil side No. 1 terminal and the alternators other lil side No. 2 terminal would be jumped/tied to the alternators big main output stud.
If its another alternator I cant say for sure as I have absolutely no wiring diagrams of them. Maybe some of the other fine gents have some alternator data or wiring diagrams???
John T
Osage
09-01-2005 18:09:16
 Re: Gen Lite Wiring Connections with an Alternator in reply to John T, 09-01-2005 16:18:07
John T:
Thanks for the prompt reponse.
The Gen Lite(Idiot Lite) is the dash mounted lite that was wired originally for the 12v Generator. However when they changed to the Alternator, they just left the lite wire hanging.
I have no idea what type of Alternator, however it does look a lot like a GM.
Tomorrow I guess I'll dig a little deeper,
Osage
John T
09-01-2005 19:25:53
 Re: Gen Lite Wiring Connections with an Alternator in reply to Osage, 09-01-2005 18:09:16
See if it has two lil terminals on the side marked 1 and 2 and the big main ouput stud on the back where the wire to the battery (or starter etc) leads.
John T
Osage
09-02-2005 04:05:45
 Re: Gen Lite Wiring Connections with an Alternator in reply to John T, 09-01-2005 19:25:53
John
It is a Delco-Remy Alternator with an output stub on the back and a two wire modular plug on the side(green & black wires).
When daylight comes, I'll try to figure out more.
Thanks again,
Osage
John T
09-02-2005 06:15:22
 Re: Gen Lite Wiring Connections with an Alternator in reply to Osage, 09-02-2005 04:05:45
Osage, its sounding more n more like a Delco 10SI which wires as I guessed at in my very first post to you, i.e. the idiot light wires to the lil No. 1 terminal (other side of idiot lights receives voltage when tractor switched ON) and the lil No. 2 jumps up to the other lil No. 2 terminal.
John T
Bob
09-02-2005 06:00:55
The system should work by simply connecting the wire from the "GEN" light to the alternator's #1 terminal.
The #2 terminal gets jumpered over to the large output stud, or even better, to the battery cable connection on the starter solenoid, for more accurate sensing of actual voltage at (near) the battery.
There's a lot of good information about 3-wire Delco alternators and remote voltage sensing on MAD electrical's site. It's geared to the hot-rod crowd, but would apply equally to a tractor converted to a Delco alternator.
John T
09-02-2005 06:16:59
 Re: Gen Lite Wiring Connections with an Alternator in reply to Bob, 09-02-2005 06:00:55
Bob, that looks like a great information source, thanks for posting that link. Sounds like he has a 10 SI now.
John T
Osage
09-03-2005 18:36:51
 Re: Gen Lite Wiring Connections with an Alternator in reply to John T, 09-02-2005 06:16:59
Thanks again, John T & Bob I think by trial/error I can figure this one out.
Osage
