730D RPM VARIATON
bruce schepler
09-01-2005 13:44:58
HELP,STILL TRYING TO GET 730DW/PONY START TO RUN PROPERLY. WAS ONLY HITTING ON 1 CYLINDER. HAD INJECTORS CLEANED, MEASURED FUEL PRESS. FROM TRANSFER PUMP TO FUEL FILTERS CAME UP WITH 32PSI,REMOVED AIRFILTER ASSY AND CLEANED OUT, REMOVED FUELTANK AND HAVE MOUNTED A SMALL 2 1/2 TANK TO GET RUNNING. TRACTOR RPM NOW SURGES FROM 1100-1350 RPM AT FULL THROTTLE. ANY IDEAS? STILL DOESN'T PULL. THANKING YOU IN ADVANCE FOR ALL YOUR HELP.
msb
09-01-2005 20:52:45
 Re: 730D RPM VARIATON in reply to bruce schepler, 09-01-2005 13:44:58
Sounds like it has some air in the pump manifold and or fuel filters.Does your tractor have a check valve(it was an optional update-- on the customer) in the return line,on top of the injector rack cover?If so sometimes it helps to remove the check ball and just let the fuel flow for several minutes while watching for air bubbles.Take the check apart.Seems like it takes a 1 1/8" wrench?You will have to plug the return line of fuel will back feed from the tank.I have seen the time when it might take a half day to completely bleed one of those tractors.Have you bled the filters while the tractor is running?May have to do it many times.Just crack the plugs and watch for bubbles.
Those tractors would ,on occasion -especially if overspeeded, throw off part of the lead on the govenor weights and cause what seems like a miss and cause erratic engine speeds.
buickanddeere
09-01-2005 17:43:03
Have you adjusted the pivot point linkage?
mike brown
09-01-2005 16:23:01
variations in rpms at constant or no load means variations in fuel injection quantities. Does the rack under the inj. pumps move freely? Is the spring on the right side that pushes the rack back to idle in good shape? If the answer to both is yes then you have to go back toward the governor and check that every thing is free and functional. There are lots of linkages and springs and weights that all have to work right.
