4020 decals
Tom/Idaho
09-01-2005 05:03:21
The local dealer said JD no longer makes all the decals for a 4020 #68020, power shift. I found on this board that one can order a decal set for a 4010. What is the difference in decals between a 4010 and a 4020 or does someone know where I can order a 4020 set? Thanks, Tom/Idaho
partsguy
09-01-2005 11:06:10
 Re: 4020 decals in reply to Tom/Idaho, 09-01-2005 05:03:21
they no longer make the kit, you have to get each decal seperate
kwgray
09-01-2005 05:29:37
Check this out:
K&K Antique Tractors
Link
or
Travis Jorde
http://www.jordedecals.com/
Mike Aylward
09-01-2005 13:56:39
 Re: 4020 decals in reply to kwgray, 09-01-2005 05:29:37
I have seen K&K's decals for the New Generation tractors and they seem way too big and thick. They are not right if you compare them to an original tractor. I have not seen Jorde's decals for the newer tractors but if his previous level of quality is maintained they should be good. The K&K decals can be spotted at 50 paces. Mike
SMm in Wi
09-01-2005 15:24:09
 Re: 4020 decals in reply to Mike Aylward, 09-01-2005 13:56:39
Are you sure you saw an original tractor? I have K&K decals on my 4020 and 620, and i think you full of it. My 4020 had never been repainted before, and it had original decals. The ones i got from K&K match right up!
Mike Aylward
09-01-2005 20:26:14
 Re: 4020 decals in reply to SMm in Wi, 09-01-2005 15:24:09
Thank you for your vote of confidence. I have an original 4020 and have seen the K&K decals on tractors at shows. They are nowhere near right. I will stand on that. Mike
SM in Wi
09-02-2005 03:54:27
 Re: 4020 decals in reply to Mike Aylward, 09-01-2005 20:26:14
Like i said. your full of it. Take the paint off of you 4020 down to steel like i did. My 4020 had only one set on it. The original set of decals.
Mike Aylward
09-02-2005 10:40:42
 Re: 4020 decals in reply to SM in Wi, 09-02-2005 03:54:27
My 4020 is original. No need to get in a pissing match. I will stand on my story. I have seen many of these decals at tractor shows and they are obvious. Your opinion is up to you. If you like them, go for it. I will not. Mike
KWGray
09-02-2005 11:05:42
 Re: 4020 decals in reply to Mike Aylward, 09-02-2005 10:40:42
Maybe This will help. In color and graphical dimensions, the K&K decals are the same as what came on the New Generation tractors from the factory but to obtain the color combination K&K uses a two layer system to achive the look which might make them look three dimensional. The Deere factory used silk screening to apply their decals and that is the only way (unless you are really good with a paint brush) to achieve the original look. I have never seen Jorde decals and I used K&K on my 4010 and think it looks just fine. Much better than the mylar ones Deere sells at their parts counter. I"ve seen mylar decals and it looks terrible - like the decals used in model airplane kits. I was only giving options that I knew of and assumed Tom in Idaho could make up his own mind.
