4020 and 1000 pto implements and mid pto
Nylon
08-31-2005 20:46:53
What kinds of implements can 4020D '68 run well/reliable at 1000 pto rpm? What was most common mid front pto used for? I would love a front mounted 2 stage 7 foot snow blower. Do these exist? Does the long shaft to the front pto stress and break somewhat easier? Can the front pto spline be interchanged byu circlip with the rear pto or is it fixed?
Bob
09-01-2005 08:06:25
 Re: 4020 and 1000 pto implements and mid pto in reply to Nylon, 08-31-2005 20:46:53
There are front PTO driven snowblowers. Deere sold a unit, I believe a Canadian-made McKee, under the Deere name. There are still a few of those around here. Erskine Manufacturing made them until fairly recently, I don't know if any are still available since Melroe bought out Erskine.
The front PTO is 1000 RPM ONLY. The shaft is actually front-driven, by a gear just inside the housing, so the front PTO is actually NEARER to the power source than the rear PTO.
CMB
09-01-2005 09:43:50
 Re: 4020 and 1000 pto implements and mid pto in reply to Bob, 09-01-2005 08:06:25
Actually, on a 4010 the front shaft turns either 540 or 1000 RPM depending on which rear shaft is installed. We thought it always turned 1000, until, many years ago when we first mounted a #50 side mount mower & wondered why the mower ran so slow. Sure enough, when the 1000 RPM rear shaft was installed the mower worked properly!
Tx Jim
09-01-2005 03:57:18
Nylon,since I live in sunny Tx. I know zilts about snowblowers, I see no reason a frt. mount snow blower couldn't work on mid-pto,but mid pto's on new generation rowcrop tractors are only 1000 rpm and aren't designed to be altered as to rpm's. Mid-mount sickle mower,sprayer pumps and possibly an aux. hyd.pump can be powered there. Tx Jim
