420w changing to 12v
TIMAR
08-31-2005 18:40:27
I know I need to change the light bulds to 12v, but do I need to do something to the generator?
I want to run a 12v sprayer behind it.
buickanddeere
09-01-2005 03:45:52
 Re: 420w changing to 12v in reply to TIMAR, 08-31-2005 18:40:27
You could just hang a 12V alternator off the side and run the sprayer from it and any old 12V battery?
James Nauert
09-01-2005 02:28:49
Can you just mount a 12v batt. on the spray unit. Run it off of that just recharge it when you are done. My 420 is coverted to 12v because the guy i bought it from had the gen rewound for 12v. I think i would have left it a 6v.
John T
08-31-2005 19:01:39
Timar, Im NOT saying its proper or good engineering practice, but I have used 6 volt Generators and changed to a 12 volt Voltage Regulator and they worked to charge a 12 volt battery. Or have a Generator shop convert it to 12 volts or just buy another 12 volt Generator.
If you change from 6 to 12 volt you can EITHER use the existing 6 volt coil but add a series voltage dropping (12 to 6) Ballast Resistor (around 1.5 to 1.85 ohms) ahead of the coil between it and the Ign switch ORRRRR change to a full 12 volt rated coil.
John T
