420T Clutch
JWHum
08-31-2005 18:06:12
Does anyone know where I can get the 11" clutch disc rebuilt for a 420T with live PTO?
buickanddeere
08-31-2005 21:18:54
 Re: 420T Clutch in reply to JWHum, 08-31-2005 18:06:12
Spicer made those clutches for JD and Massey among others. You can scroung some parts from a Massey model 35 etc. As for mixing a used clutch disk with another unmatched flywheel and pressure plate? That is wishful thinking if the plan is to save time and money. You better study up on the service manual and service bulletions in order to set up the clearances. Or you will get to do the job all over again.
Henry J
09-01-2005 05:19:59
 Re: 420T Clutch in reply to buickanddeere, 08-31-2005 21:18:54
Well this dumb ole country boy may have wasted a little time but I differ with you on the money. My 420 with used disk performs exactly like a new one and will probably be that way long after I am up there looking down on the tractor. And the clutch is smooth as silk.
I understand that you can never go wrong with "new", mater of fact I feel confident that buying a new tractor would fix it also. That way you would get a new flywheel and pressure plate to boot. In my particular case it worked out that .050 had to be factored in for the wear on the used plate.
I been there and done that. Matter of fact I think the measuring tool I made is still laying in the scrap metal pile.
And I know that I wasted in the line of $30 for the disk.
buickanddeere
09-01-2005 17:50:32
 Re: 420T Clutch in reply to Henry J, 09-01-2005 05:19:59
Your point is? And the pride in tossing measuring gauge on the scrap pile? How about all the blotched clutch jobs that were done with worn or grooved parts and heat damaged springs etc?
JWHum
08-31-2005 21:25:11
I think you're right. The service manual says you need a new clutch disc in order to get the correct adjustment.
Henry J
08-31-2005 18:23:22
JW
You might consider using a used one. Good ones are availabel real reasonable compared to rebuilt or new.
JWHum
08-31-2005 18:34:04
 Re: 420T Clutch in reply to Henry J, 08-31-2005 18:23:22
Where would I look for a used clutch disc?
