1957 JD 720 2-Cylinder Camshaft Timing
Help Needed
08-31-2005 16:59:24
I have a JD 720 2-cylinder that is 180 degrees out of time. Does anyone know the best way to correct the timing, it runs on one cylinder. What needs to be removed for the quickest way to do it and do you have to remove the camshaft ???
Any advice would be very appreciated. Thank you.
Help Needed
09-01-2005 04:15:10
 Re: 1957 JD 720 2-Cylinder Camshaft Timing in reply to Help Needed, 08-31-2005 16:59:24
My JD 720 Tractor is a Gas Tractor.
Just bought it on a Consignment Auction Sale and I double checked it and the Camshaft is out of time.
buickanddeere
09-03-2005 09:33:25
 Re: 1957 JD 720 2-Cylinder Camshaft Timing in reply to Help Needed, 09-01-2005 04:15:10
May as well pull that cam & followers and send them to Roberts Carburator when it's apart. They will be worn and affecting valve lift and timing as well.
mike brown
09-01-2005 06:59:26
Did you check it by the marks on the case with the flywheel marks? Did you double check with the plugs out and feel for the piston tops on compression stroke ( in case the flywheel is on wrong or slipped). If you have seen the gear train that runs the cam shaft there is virtually no way for the cam to slip out of time. It would have to have been removed and reinstalled wrong or have serious damage to the gears that drive it. I don't know how the cam gear is held onto the shaft. If it's by woodruff key I suppose that may have failed.
help needed
09-01-2005 18:44:35
 Re: 1957 JD 720 2-Cylinder Camshaft Timing in reply to mike brown, 09-01-2005 06:59:26
Thank you, Mike
Somebody else has overhauled the 720 and put the camshaft and crankshaft 180 degrees off.
I checked all the marks on the camshaft and flywheel, when the marks are correct on the camshaft, top dead center on the flywheel is on the bottom and again the marks are where they belong. I just wanted to know what the quickest way is to put it back in time.
buickanddeere
08-31-2005 21:20:41
Gas or diesel info would help. What all was done with the tractor?
greenmech
08-31-2005 19:52:19
Could it be just the distributer is 180 out of time? How did it get out of time? Was it after an overhaul? Ron Mn.
xragman
08-31-2005 18:49:53
if it runs on one cyl. it is not the cam unless you had it out and put it in wrong.
xragman
08-31-2005 18:45:02
