JD 450C Engine sputter and dies
Larry Sramek
08-31-2005 09:20:40
I have a JD 450C and can not figure out the problem I am having with it. The thing will run fine for 10 or 15 minutes and then the engine starts sputtering and then it dies. The fuel is clean and has no water in it. The fuel lines and fuel filter have been replaced. We have noticed that when it does this, we can loosen the two bolts on the side of the injector to the point of getting a small drip going and then it will start and run fine. Any ideas as to what could be going on with this? Any advice would be appreciated.
WTW
08-31-2005 10:35:37
 Re: JD 450C Engine sputter and dies in reply to Larry Sramek, 08-31-2005 09:20:40
Larry, If the two bolts that you are loosening / referring to are the two screws retaining timing window on the side of the injection pump, you are allowing return fuel to exhaust from side of pump that normally should be returning to tank. This condition tells me you return elbow or line or both between tank and injection pump is plugged / restricted and most likely due to a failed weight retainer flex ring in your injection pump. Pretty common problem with a Rosa Master pump with some hours on it. Pump will have to be removed and repaired and return lines and special elbow fitting will have to be removed and cleaned of rubber grindings from failed flex ring. Elbow fitting at pump is special due to spring loaded glass ball inside it which maintains pump crankcase pressure. Good chance fitting will have to be replaced. Good Luck, DW
