4010 - hard to add dual remotes?
RFox
08-31-2005 08:29:21
My 4010 has a single remote right now and I neded two of them. I'm trying to decide whether its best to just add a closed center dual spool on the fender or just add another factory type remote on the dash. Is there much work to adding another remote on the dash? and back end?
Thanks, RFox
txgrn
09-01-2005 05:43:40
 Re: 4010 - hard to add dual remotes? in reply to RFox, 08-31-2005 08:29:21
Mine has the second control. The slot was already in the dash. The spool box mounted against the orig and as I remember was fed from it. The guy just ran the outlets out on 2' hyd hose to right above the starter.
I use it on my JD 1209 swather for position control while the main one is lift. So on my swather I made the position control hoses about 5' longer than the other and run them between the lift arm and center section and let them lie on top of the floorboard. Works just fine.
So in this guy's application, he was only out the cost of the control box....per se. So you can go either way and it will work.
Mark
Tx Jim
09-01-2005 04:07:00
RFox,once you get hood,piece in frt of dash,floorboard and rockshaft cover off,it's not too bad if you have correct parts.Tx Jim
JMS/MN
08-31-2005 08:41:31
Salvage yards are a good source for adding factory valves- make sure you get the right plumbing- valves are identical and stack one over the other under the hood. Another source of remote power is: in front of the brake pedals is a line that feeds the rockshaft. Replace that elbow with a T, and feed from the T to a fender mounted valve. I used hydraulic couplers in the line so I could disconnect when not needed, eliminating unnecessary flow.
