Brad, The following may help in timing your ES mag on your D. It is a bit different than the base mount Splitdorf - that is why I asked. It sounds like you have a flywheel issue also, but the "impulse" is the important part, and that should line up with the mark on the case when the magneto impulses.The ES CD spec 0010 magneto does not provide a spark for each impulse click - it only provides a spark for the compression stroke of each cylinder. Wico magnetos, for example, provide a spark for each impulse click - that amounts to providing a spark on the exhaust stroke also. The ES series is click (spark), click (spark), click (nothing), click (nothing), and this cycle repeats itself. So, lay your spark plugs where you can see them spark, connect them to the magneto and rotate your magneto enough times that you can predict when the right hand terminal on the magneto is going to spark, followed by a spark from the left hand terminal. Then put your thumb over the flywheel side cylinder (#1) and determine the compression stroke - you will feel a rush of air as the piston moves forward. When you are at the top of the compression stroke (flywheel will have "LH Impulse" lined up with mark on transmission case), rotate the magneto drive cup such that it will produce a spark at the right hand terminal, put the magneto on the tractor and connect the right hand wire to the flywheel side plug. Then rotate the flywheel 1/2 turn more (bringing #2 piston up on compression) and you should see a spark at the pulley side. As a test, rotating through two more impulse clicks will produce no spark, then you should be back at piston #1 coming up on compression and the magneto ready to fire it. Once you confirm this operation, put the plugs back in the tractor and the magneto should be providing spark to the proper plug. At that point you can follow the instructions about rotating the magneto until it impulses when the mark on the flywheel aligns with the mark on the case. Kind of a long explanation, but after you understand that 1) you don't get a spark every click, 2) the magneto produces a spark at the right hand terminal, then the left hand terminal, and 3) you must have a spark at #1 (flywheel side) on compression, followed by a spark at #2 (pulley side) on compression, you will get it figured out. I figure since these magnetos were made during the depression, they conserved everything back then, including sparks.
