John Deere A oil pressure
Ardie
08-29-2005 03:54:55
I have A 46 A which I have'nt started for probably 4 months. After it started I noticed no oil pressure on the guage, it has always had good oil pressure. It has oil in engine, what do I look for. Thanks for your help.
James Nauert
08-29-2005 14:24:37
 Re: John Deere A oil pressure in reply to Ardie , 08-29-2005 03:54:55
Make sure that your carb. didn't leak a bunch in to the crankcase this will thin the oil enough to give you a false read.
DW
08-29-2005 13:13:30
An often overlooked item, take the gauge line off and make sure there is no blockage. Also turn the engine over to see if there is oil where the fitting comes out of the main case. If not, proceed to checking the coupler to the pump etc.
Spoker
08-29-2005 05:14:00
Look inside the engine there is a shaft that drives the oil pump that comes down from the govener. It has a coupling from the cam shaft to the oil pump. The coupling might be broke or the cam gear that drives the shaft might be striped. Better hope it is the drive coupling on the drive shaft to the oil pump.
