Typically, that happens when dirt, moisture, and brush or contact residue build up in the starter, starter solenoid, generator, or regulator, and the moist, conductive crud bleeds the RH battery dead. The "guts" of the starter, generator, and regulator are (supposed to be) isolated from chassis ground, and the voltage regulator cutout section and the starter solenoid only disconnect one half of the split 24-Volt system, so the innards of the starter, generator, and regulator are electrically "hot" all the time. So it is important that their insides be clean and dry, and the insulation on the windings must be in good shape. The above units can be disassembled, and thoroughly cleaned out with a brush and compressed air. It is possible to have bad insulation on starter or generator field windings that will "act up", even after the unit is cleaned out. Dirt and moisture in the key switch or the light switch can contribute, too, and also, if there is any damage to the insulation on a battery cable(s) where it runs under the operator's platform, and usually lays in wet dirt, there will be an electrical drain there, too.
