4020 clutch life?
Nylon
08-28-2005 20:06:25
I read the post on the clutch and am wondering how to gauge the current status of a clutch. Mine just doesn't seem to have the gradual clutch grab that say a motorcyle has. The clutch on my 4020 is either on or off....no real slipping of the clutch if you wanted to. I looked up into the access and the assembly apears to be pretty new. At least from the back of the basket. It looks like it has been replaced with a basket that has the part number written on the back in black marker. Reman? I have set the free play to 1". How does free play work? It seems opposite to me as what it should be.
My clutch seems to hold strong as i took it up and down very steep ditchs and grades in several different gears as well as reverse to make sure that it wouldn't pop out unexpectedly.
Any info would be great.
Thanks,
John
buickanddeere
08-28-2005 20:44:41
 Re: 4020 clutch life? in reply to Nylon, 08-28-2005 20:06:25
Depends on which clutch facing material was used. I had the highest friction facings put in the Spicer clutch in my 435. Didn't want it to slip when she's turned up a little for pulling. It takes some learned and careful feathering of the clutch pedal and lower rpms to limit the engagement jolt.
Nylon
08-29-2005 09:25:24
 Re: 4020 clutch life? in reply to buickanddeere, 08-28-2005 20:44:41
That seems to be it. I don't have engagement jolt and I dont need to feather at all. I would think that I would have to but I do have rpms low when I do it.
