1939 JD B timing
Brad calp
08-28-2005 19:04:04
I am having trouble timing my B. I am sure that the marks on the crank gear and the mark on the cam gear line up together? Then the cam gear and governer marks line up? But I am unsure of the cam gear being 2 times bigger then the crank gear. So how do you know when to line up the marks? Does anybody know where I can get a timing sequence of how it is to be timed? Please help I have a show in the end of sept. and would love to go. thanks Brad
John T
08-28-2005 21:01:22
 Re: 1939 JD B timing in reply to Brad calp, 08-28-2005 19:04:04
Brad, to start with in order that the timing marks on the flywheel can give an accurate indication,,,,, ,THE FLYWHEEL MUST BE ON THE CORRECT CRANK SPLINE and to avoid vibration the clutch disk must also be in time and on the correct spline over on the other side.
Nowwwww w, Ifffff ffff the flywheels on the correct crank spline and Ifffff fffff ffff the cam (its drive gear is twice as big as crank gear cuz it runs at 1/2 its speed) is timed correct to the crank, when the Flywheels Left Hand Exhaust timing mark is in the 3 o clock position lined up with a flat mark on ths tractors side just behind the flywheel,,,,, ,,,,,THE LEFT HAND EXHAUST VALVE SHOULD JUST BEGIN TO OPEN.
Nowwwww ww, if the flywheels on correct spline,,,,, ,and crank is timed to cam,,,,, ,,and governor gear is timed correct to the cam gear,,,,, when the Flywheels Left Hand Impulse is in the 3 o clock position lined up with that mark on the tractor,,,,, ,,,,,
1) The Left Piston ought to be at TDC
2) The female slot in the governor shaft end (where mag mates into)
ought to be flat horizontal fore n aft
3) The mag should just snap to fire the plug wire to the left cylinder (originally top cap terminal was to left and bototm to right, it may be reversed???)
Also if all is in time (Flywheel on correct crank spline), when the left piston is at TDC the slot in the flywheel is also fore n aft flat horizontal like the slot in the governor shaft end is. If the governor gear is out of time with the cam, it has to be raised and rotated and reinstalled so its like described above. The governor shaft turns in the same direction and RPM as the crank ya know.
John T
