Fuel Capacity on a 2510
Dug
08-28-2005 18:44:49
Just wondering the fuel capacity on my JD 2510, gasser. Also, fuel usage while bush hogging. Going to mow a field, about 4 acres, for a friend and just going to charge him fuel costs.
Thanks,
Dug
Dan Streed
08-31-2005 18:37:54
 Re: Fuel Capacity on a 2510 in reply to Dug, 08-28-2005 18:44:49
Dug,
I also have a 2510 and it's owner's manual. According to the manual, the gas tank holds 26 gallons. Can't help you out with the usage, though.
Dan
2510 in In
08-28-2005 19:40:00
ain't it a witch when gas reachs the point where it figures in mowimg a 4 acre field? That sounds about the right fuel useage for my 2510 too,,,
Dug
08-28-2005 22:06:21
 Re: Fuel Capacity on a 2510 in reply to 2510 in In, 08-28-2005 19:40:00
Yep, and it's only going to get worse! Filled up the farm truck and 5 five gallon jugs and the bill came to $101! It used to be fun to putt around on the Ole JD, now I need a part time job just to run her.
Dug
jdman(MO)
08-28-2005 18:59:02
The 2510 holds 26 gallons. Mine does not seem to be a real gas hog, and it seems like a tank full lasts quite a while while brush hogging. The GPH will depend on the load, I would guess about 3-4 gallons per hour. Russ
Dug
08-28-2005 19:13:56
 Re: Fuel Capacity on a 2510 in reply to jdman(MO), 08-28-2005 18:59:02
Thanks, Russ.
Dug
