1968 or 69, 4020 Clutch
Surge
08-28-2005 08:09:33
Hello,
I am very worried about my tractor and nervous to find out what it may cost for the repair. When moving hay yasterday my clutch must have started slipping. It has done this before another time and we adjusted it and everything was fine. Tried adjusting it and the tractor still wouldn't move. We let it cool off a while and it worked for a while longer and stopped again. left it for the night and just went back out and I had nothing. It would not move. Am I looking at a total clutch replacement? and if so what is the price range I am looking at? Is ther a possible other option to try and further the life of this one some how as a large repair cost is a huge concern. I saw in the search that someone mentioned that it was not that tuff of a job. Is this true and is it pretty straight forward or requires a tractor mechanic to do it. also, What would you say would be the time frame for the repair?
Thanks and any help would be greatly appreciated!
MSM
08-28-2005 10:35:18
 Re: 1968 or 69, 4020 Clutch in reply to Surge, 08-28-2005 08:09:33
To do it correctly you are looking at around $2000 total including parts and labor.This includes a reman clutch assembly,new pilot bearing,machine both surfaces of the flywheel,replace rear main seal and input seals on the trans shafts. It may be higher if you have a loader on the tractor,or a cab. If you do not have splitting stands,jacks,and the special tools to do it,hire it done. You can do alot more damage to the tractor or yourself if you aren't experienced or equipped to do it properly.
buickanddeere
08-28-2005 11:22:15
 Re: 1968 or 69, 4020 Clutch in reply to MSM, 08-28-2005 10:35:18
If a Deere dealer did the work. There would be some warrenty or liabailty on thier behalf. Should something fail before it's time. And no claims by the company/parts dealer the parts were not installed correctly. Joe's tinker shop and your own shed doesn't have that warrenty.
Silver Pig
08-28-2005 10:05:36
While you have it split, I would consider replacing the rear main seal, the packings on the PTO pistons, and the seals on the PTO and transmission shafts. Split it once and be done with it.
Bob
08-28-2005 09:15:21
If the clutch has been that hot, likely the pressure plate springs have been weakened, and the pressure plates could be damaged.
Deere has re-man clutch kits in the $600.00 to $800+ range, depending upon your serial number, and what transmission clutch plate you choose.
If your damage is minimal, it is possible to have the pressure plates reground, and replace the springs, but if there is severe damage, likely the re-man kit will be cheaper than the individual pieces and machine work.
The flywheel will need to be checked, and then either reground, or replaced, if worn beyond limits, or severely cracked.
If re-working the old clutch assembly, the use of a special "jig" is needed to set the finger height.
A spare pilot shaft or clutch alignment tool is needed.
Book time, if I recall correctly, is only 6 or 8 hours to split the tractor, R+R the clutch, put it back together, set the fingers, and reassemble the tractor!
buickanddeere
08-28-2005 11:19:41
 Re: 1968 or 69, 4020 Clutch in reply to Bob, 08-28-2005 09:15:21
I agree, after driving the tractor until it stops on three different occassions. The entire clutch assembly has seen a lot of heat. Most of the wear and some of the heat damage occured over some time when the clutch pedal freeplay was too tight. The only thing that cost myself more than doing a repair job correctly. Was doing the repair job over again when the 1st try failed.
Surge
08-28-2005 09:30:28
Bob, Thanks for the info! Can you give me an idea on how much I may be looking at for the labor? This ia not a shuttle shift so I think it is a Syncro.
Thanks
Bob
08-28-2005 09:51:37
 Re: 1968 or 69, 4020 Clutch in reply to Surge, 08-28-2005 09:30:28
Well, figure 6 or 8 hours at the HIGH dealership rate, plus all their miscellaneous charges, or probably 15 or 20 hours at an independent shop's (hopefully) lower rates!
Surge
08-28-2005 10:32:47
 Re: 1968 or 69, 4020 Clutch in reply to Bob, 08-28-2005 09:51:37
Bob, please excuse my ignorance but what is the average dealership hourly charge? I haven't dealt with them before so I really don't have any idea.
Thanks for all of your help!
Bob
08-28-2005 10:37:25
 Re: 1968 or 69, 4020 Clutch in reply to Surge, 08-28-2005 10:32:47
Likely in the $50.00 to $90.00 range.
Surge
08-28-2005 14:38:39
 Re: 1968 or 69, 4020 Clutch in reply to Bob, 08-28-2005 10:37:25
Thanks Guys for all of the advice. I'll check with a local JD dealer tomorroe. Silver Pig, Thanks for the tip on replacing the mail seal and other items. Do you have an idea on how much additional that may run on top of the clutch replacement?
Thanks again!
