D brakes
Chris Willy
08-27-2005 14:48:12
I am working on a D john deere, and got it all running and sounding great, I have one thing yet to do before its ready to paint and that is get the brakes freed up. They seem to be stuck under the seat in the two square bushing holders that hold the shaft that runs between the brake pedal and the linkage that goes up to the brake. Does anyone have any ideas on getting them freed up. I"ve tried heating them and penetrating oil all with no success. Thanks for the help.
Chris
Glen in TX
08-27-2005 16:21:14
 Re: D brakes in reply to Chris Willy, 08-27-2005 14:48:12
Square bushing holders. Individual brakes then. If you can get them unbolted you might be able to hold those in a press to get it out and loose. Both setups on D brakes makes me think the JD engineers never planned on anyone using them this many years down the road and put no grease zerks on those?
Earl-IL
08-27-2005 20:54:24
 Re: D brakes in reply to Glen in TX, 08-27-2005 16:21:14
What was the first year they had turning brakes on a "D"? Earl
Glen in TX
08-27-2005 22:25:12
 Re: D brakes in reply to Earl-IL, 08-27-2005 20:54:24
According to parts books sometime in 36 when they went to a 12 spline axle but other evidence maybe 35. Could have been some even earlier on a few DI ?? Never seen turning brakes on anything but styled Ds in this area.
Glen in TX
08-27-2005 15:07:38
Chris, That is no fun to get loose for sure. Been there. Do you have the individual brakes or single service brake on trans? Individual ones were a little more uncommon. On those you can unbolt the bushing blocks I believe. What I had to do was cut the shaft out with torch and get a new shaft made with keyways cut in it. Otherwise it's back to more penetrating oil and heat and 36" or 48" pipe wrench with cheater pipe. I don't know what else to tell you but good luck!
