Clutch on JD 4020
Darryl Nealis
08-26-2005 19:33:39
Can anyone tell me if a John Deere 4020 has 2 clutches in it. One for the tractor and a seperate one for the power take off. Thanks in advance for any information.
msb
08-27-2005 21:29:11
 Re: Clutch on JD 4020 in reply to Darryl Nealis, 08-26-2005 19:33:39
Syncrorange transmission tractors have a clutch that is normally engaged for the engine and a clutch for the PTO that is normally disengaged.In other words when you engage the PTO clutch you are actively forcing the pressure plate against the clutch disk,similar in theory to the old two cylinder clutches .The powershift has an engine disconnect clutch for the engine(for cold weather starting only),a compound pressure oil activated clutch pack for the transmission and a pressure oil activated clutch pack for the PTO.
Mike M
08-26-2005 19:40:20
I think it depends on the year and if power shift or not. Ours is an early one with syncro range and has the big pto lever on the RH side of the cowl. It has two seperate clutch disks.
