730 seat
hartley
08-26-2005 14:12:35
i have a float ride seat that i am trying to restore i need to know how to remove the 4 pins that the seat rides on it looks like i have to cut the brackets to remove the pins the new pins that i have, are straight with a raised section in the middle of them the bushings on each side of the old pins keep the pins from being removed any help please
Spoker
08-28-2005 10:20:23
 Re: 730 seat in reply to hartley, 08-26-2005 14:12:35
Get you some C-Clamps. They will aid in getting the torque springs in place and set. If you use a punch and sledge hammer, which I did, use a back up of some kind (small board)so as not to bend the arms when driving the pins out. Sure helps. Some times it works if you set the battery box back on the tractor and then set the torque spring using the c-clamps
Bruce L
08-27-2005 20:57:42
I've done a couple of these and I agree, the air hammer zip gun with the proper size bit is the way to go. Those pins just come right out with that approach. The service manual shows use of a hammer and a punch but that doesn't work nearly as well.
Paul Price
08-27-2005 15:42:47
 seat for my M in reply to hartley, 08-26-2005 14:12:35
I understand there is someone named Leland Swant (don't know if last name is right), who can make me a new seat. Does anyone know how I can contact this person?
SM in Wi
08-26-2005 17:46:08
I have just what you need! I have a copy of the pages from a 820 service manual showing disassembly, inspection and repair, and assembly of the Float ride seat. I copied this from a friends manual when i replaced the torsion springs of my 620 seat. This realy helped!!
If you or anyone here would like me to send this to you e-mail me. Its 4 pages.
hartley
08-27-2005 08:59:42
 Re: 730 seat in reply to SM in Wi, 08-26-2005 17:46:08
what is your email address
Soldier Tom
08-26-2005 17:19:18
I did the one on my 720 this spring. I don't have any air tools, I whacked a 1/2 inch drift with a sledge hammer, while the seat was resting on some 2x4s. I understand it you heat them up cherry red they will often "break loose" but I don't have a torch either.
Definately drive them OUT or you will break the inner ears off. Be sure to keep up with the spacers too. They didn't come with my bushing set, and having lost one I had to "create" one from 1" stainless tubeing. There are some threads on here from when I was doing mine that may be useful. Oh, be sure you get the handle facing the right side of the seat. I wasn't paying attention and mine ended up "left handed". oops.
WHAT a difference it all makes tho! NICE. especially if you USE it much.
~Walk in peace~
BushogPapa
08-26-2005 16:25:21
Drive the pins OUT....toward the outside of the frame...not "in"... Drive the new pins in, in the same direction....from the Inside, toward the outside.. Yep..that adjuster can be a Bugger...!!
elv8orman
08-26-2005 15:59:55
I just finished the seat on my 620. I used an air hammer on my pins to drive the pins out. Worked like a charm. My biggest problem was the torsion springs and adjuster asembly. Good luck on your project
hartley
08-27-2005 08:58:22
 Re: 730 seat in reply to elv8orman, 08-26-2005 15:59:55
thanks a bunch
