Axle Felt: lube or not to lube...
Jason Z in MO
08-26-2005 14:07:59
Getting ready to install my rear axles. The procedures are clear but there is no mention of putting any lubricant on the felts.
Should they be installed dry?
If I don't soak them in some oil will they absorb water?
I looked through the archives but couldn't find anything on lubricating them.
Mike M
08-26-2005 19:44:19
 Re: Axle Felt: lube or not to lube... in reply to Jason Z in MO, 08-26-2005 14:07:59
The ones I used to get from Deere had some kinda clear grease in them allready.It would squeeze out when assembled so I never really added more like I think the book says to. If they are dry soak in oil for sure.
Glen in TX
08-26-2005 15:48:49
Soak them in some new clean oil and let them drain off before installing or sqeeze excess out on some rags or some wood you want oiled down.
