70d ignition switch
stu in njo
08-26-2005 07:00:12
Is there any place to get one jd dealer says thay are not stocked any more. Is there one I can replace it with? Also is there any way to get calcium to stop eating the rims up? Thanks Stu
Scarecrow
08-26-2005 17:00:02
 Re: 70d ignition switch in reply to stu in njo, 08-26-2005 07:00:12
I have been restoring a 70 Diesel and had to replace the ignition switch. I had no problem getting it from John Deere.
buickanddeere
08-26-2005 11:56:54
The number subs a couple of times but it's still stocked. Your dealer's part person is just lazy. Make certain you don't get a 24V electric start or 12 gasser switch. They do get mixed up.
StuBC
08-26-2005 07:46:35
I found mine at Napa, it was very very similar to original. I forget the make (CHL?) but its in their standard wire connector, switch catalog.
Mike M
08-26-2005 07:27:24
If you have an old switch now that is just acting up take it apart and clean it and restake the posts. You may still find some in the salvage yards. To stop the calcium from eating it you will need to install new tubes to get it all out. Then sandblast and paint the rims inside and out.If you need the weight do as above then pump it back in and should last for years,or if you can afford it use the new beet juice stuff.
stu in njo
08-26-2005 09:48:55
 Re: 70d ignition switch thanks in reply to Mike M, 08-26-2005 07:27:24
I'll try to fix the old one & get one from napa as back up do you remember# by chance? I'll try sandblasting someone told me that didn't work. Thanks Stu
Mike M
08-26-2005 10:39:28
 Re: 70d ignition switch thanks in reply to stu in njo, 08-26-2005 09:48:55
They may not of blasted them good enough ?
