720 D..Awesume...!!
BushogPapa
08-26-2005 04:25:57
I finally got the tires and 3-point done and on..used it on the flail mower yesterday...!! Had that flail nearly kill my 630 Gas...the 720 Never even started to Bark with it..!!! Advertised as a "Cadillac"..I Believe it..!! THANKS to the Hammerle's (in Ind.) for representing this tractor as it really IS..I would buy from you folks "sight unseen"..!!!!
Ron..
720Deere
08-27-2005 07:01:29
 Re: 720 D..Awesume...!! in reply to BushogPapa, 08-26-2005 04:25:57
The 720 diesel is a powerhouse, but if you really want to feel unstoppable, try an 80/820/830. The torque that one of those monsters makes is unbelievable. Peak hp readings aren't all that far apart on my 720 and my brother's 80, but that 80 will pull loads that make the 720 run out of power (that's in gears of the same ratio).
The hp numbers on the big diesels are deceiving. The 830 is only 75 hp, but at rated rpm, it delivers over 350 lb/ft of torque! A 94 hp 4020 for example only makes about 235 lb/ft at rated rpm. Max torque on the 4020 never even approaches that of the 830 at rated rpm. I saw some John Deere data once that said peak torque of the 830 is very close to 400 lb/ft.
The 720 runs around 275 lb/ft at rated rpm and approaches 300 lb/ft max torque. The difference between a 720d and a 620 is very noticable. When I was a kid I thought the 620 was very strong, but as your post indicated, the difference between the 620 & 720d is staggering!
BushogPapa
08-29-2005 11:24:35
 Re: 720 D..Awesume...!! in reply to 720Deere, 08-27-2005 07:01:29
Bushogged some bottom ground with the 720D yesterday..Big growth down there..actually, I had a 6 1/2' flail on it... I know how fast that flail can pull a "60" or 520 down, and wonder how far I should let the 720 pull down.. It started to pull it down some, and I am not sure if I can or should let the RPM's drop very far..since it is a diesel..without damaging the engine... I let it get down to 1,000..then rode the clutch some in the big stuff...I didn't have to raise the mower even once.!!
Mike M
08-29-2005 12:43:29
 Re: 720 D..Awesume...!! in reply to BushogPapa, 08-29-2005 11:24:35
I think you did right by not letting it pull down below 1000 rpm. I remember seeing something in the owners manual about not lugging them down and to shift to a lower gear. They will pull down and hang in allright but I bet it takes it's toll in tearing one up.
DW
08-27-2005 06:58:19
I feel exactly the same way about my 720 diesel. I truly believe you could hook to one corner of the farm, and turn the whole place a quarter turn if you took a notion. And economical too.
G/MAN
08-26-2005 07:35:49
There's a little bit of torque in that old diesel, isn't there??
BushogPapa
08-26-2005 16:10:02
 Re: 720 D..Awesume...!! in reply to G/MAN, 08-26-2005 07:35:49
Yea...!!
My JD 630 "Barks" at everything...!! Not so, with the 720 D...!
Ron..
