1020 fuel return
David Daniell
08-25-2005 19:43:42
My 1020 is blowing fuel out of the return line. I have blown out the line, took the tee"s off the injectors and cleaned them out, replaced the rubber line, replaced the gas cap to make sure it is venting. When I took the tee"s off and blew the center on out there was some reddish-brown crystal-like stuff in it. It ran good for an hour or two and then I had to blow out the middle one again. Found the same stuff in it. What is this stuff and where is it coming from? I have a new fuel filter. My return line does not have any clamps on it, should it?
msb
08-26-2005 09:39:42
 Re: 1020 fuel return in reply to David Daniell, 08-25-2005 19:43:42
There is what is refered to as a govenor weight retainer seal in the injection pump that has broken apart.I don't know why Roosa Master called it a seal(it seals nothing) since it serves to cushion the torque on the govenor weights during rapid acceleration.It is a quite common occurence on tractors that used the Roosa master injection pumps.You will need to have the injection pump rebuilt.Its not something that most should even attempt if not trained on them specifically and besides the rebuild should be done in a "clean room".Ask the repair service to install the latest govenor weight retainewr without the seal, and chances are you will never have to have the pump rebuilt in the future.
