219 engine problem
cowman2
08-25-2005 18:05:23
while blowing silage the guage line leaked and you know the rest of the story when they came to get me it was almost siesed I dropped the pan and no. 3 rod bearing worked on the crank is there anyway to fix it in the tractor
buickanddeere
08-25-2005 18:24:11
 Re: 219 engine problem in reply to cowman2, 08-25-2005 18:05:23
How long do you want the repair to last? How many hours on the tractor? Any chance the sleeves are about to leak due to old acidic coolant? This would be the time to replace them before leaking coolant takes the whole bottom end out. Murphy switches are indeed cheap insurance.
J. Schwiebert
08-25-2005 18:22:47
In my opinon you are playing with fire. When a rod journal like that gets heated you can also destroy the harness in the crank. You need to get all that metal out of there and start with a clean block and make sure your crank grinder does a rockwell test on number 3. Questions?
cowman2
08-25-2005 18:36:01
 Re: 219 engine problem in reply to J. Schwiebert, 08-25-2005 18:22:47
thanks for the feedback I was hoping for a quick fix but I should do it right the engine has 1700 hours out of a 3300 combine it uses no oil runs with plenty of power made a great tractor out of the old gas 2030
